3 way component time alignment
So im trying to figure out a good way of doing it but i want to have 3 set of 3 way components up front with each speaker individually time aligned with a subwoofer. I was looking at a set of precision power p.65c3 if they will work.
Sent from my SM-G928T using Tapatalk
Measure where all the drivers meet up in the middle and then measure from that point to your ears. Then use a song with the vocalist dead center and fine tune via adding or decreasing either left or right side until the vocals are dead center.
Where are your drivers located? You dont need to T/A the tweeters.
Sent from my SGH-T999 using Tapatalk
No im looking at 2 door woofers 2 mid drivers and 2 tweeters mid drivers and tweeters fibergalssed into apillers and woofers in doors. I want to time align the tweeters mids and woofers. Not three sets sorry about that lol didnt realize i said three sets haha. And your right that would be dumb.
Im trying to get as perfect of a sound reproduction as possible without spending a ton of money so if anybody has a better idea for door speakers under $300 id like to hear some opinions. Im going for sq and spl so i want my front stage extremely high quality and lots of bass from the sub lol
Perfect reproduction comes from tuning power not so much driver choice. As long as the driver can cover the bandwidth needed. Out levels will vary, typically the better the driver the higher it can maintain solid reproduction within its usable bandwidth.
So a cheap set of components if tuned correctly will sound as good as high quality components? Then why do we spend so much money on them if i can get a cheap set and sound just as good?
no. You spent lots on drivers because its add accuracy and more faithful reproduction. Tuning is just more overlooked than it should be. 1000$ drivers with no tuning will get you okay results. $300 drivers with $400 DSP will get you better results. Tuning is a HUGE part. however 1000$ drivers with 400$ dsp will give you AMAZING results
How about this.
Tonality-tuning
Image-tuning
Stage-tuning
Accurate-tuning
Output-drivers and power
Better the driver the better you can cover the other aspects with higher output.
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
988
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
953
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
Dskater99
Dskater99
Longmont, CO
LosIsATool
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
