240 amp alternator jeep Cherokee.
  • 3
What do you plan run? From the feed back it seems they have a number of happy customers. I would guess it is alright, not the top of the line but better than stock.
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
107
6
353
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
653
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
477
dasubmasta
dasubmasta
49022 S.W Mi
dasubmasta
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
