Jeffdachef 5,000+ posts
Gunz That Turn on Nunz
What a voltage meter does is tell you when your system is actually giving out (when volts drop below 12) and what you can do is just turn it down until the voltages are healthy again (above 12.0 volts) You can run a 10000000000000000000 watt amp on a stock electrical system with zero issues as long as you set amplifier gains via voltage. Will you get all those watts? no but your system, amp and everything will be safe and operational and you get as much performance as your current electrical system gives.
Ps the taramps is way more energy efficient than the JL as long as you arent maxing it out like a dummy.
