2015 Honda, water leak in car, Honda says coming in through speakers
  • 2
npcout
PA
My car developed horrid mold smell. I found water around the edges of the doors in the inside of the car. I took my car to Honda figuring it was a warranty issue. The told me the issue is I have aftermarket speakers installed and they were not installed water seal tight which is allowing water to leak in the car around the speaker in very small amounts accumulating overtime.
They told me Honda uses a lot of foam and water resistant barriers around there speakers because the way there drain mechanisms work, water is suppose to run through the car doors and if you don't install your new speakers with 100% water seal, water will get in around the edges.
I still have my old stock speakers and they are pretty beefy with a hell of a lot of foam and protective barriers all around them in every place.
Anyone ever heard of this? Anything I could do without placing stock speakers back in?
If the aftermarket speakers were installed improperly then I can see this happening. But if they were installed with a proper baffle and gasket then there should not be an issue.
Was the vaper barrier removed from the inner door skin when the speakers were installed? If so, this is likely the main issue...
How were your aftermarket speakers installed? Any gasket material used on the mounting surface? Was a pre-made speaker adapter baffle used or a custom baffle used? Do you have any photos from the installation? Need more info...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Not less power but less channels. Maybe upgraded all around Bose speakers as well.
9
I may end up buying the new CDT ES-08 Plus and running customspeakerpods.com 8" speaker pod.
23
3K
Just go by color to color. LF, RF, LR, RR are your speaker wires. Positive + and Negative ( black stripes ). White, Gray, Green, Purple in...
My issue is I already have the box (without the 10" adapter ring) so I'm kinda stuck on a 12, which isn't the worst thing in the world 😂 I had...
15
npcout
npcout
PA
Truthunter
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
