2014 Ford Focus: Morel Virtus 603 for front doors
  • 4
Starchild_5150
Hey guys, first time poster, could use some advice. I wanted to install the Virtus 603 component speakers in my front doors, and I know the woofer and tweeter are do-able, but have a question about the 3.5 inch midrange speaker...will have to cut a hole, right? Any advice on where?
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
849
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
5
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
8
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
Starchild_5150
Starchild_5150
Madera, CA
Jeffdachef
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
