2013 Ford Taurus Limited SQ install
So while I was at SBN I was able to get a much better idea what equipment will be ran in this.
I did want to do either a full install of either PPI or SS, but each brand has it's own high points, so it will be a mix of both.
Amps- Soundstream Reference. These amps have too good of a name not to use them, haven't decided on which amp selection but it will be the Reference line for sure.
Components- PPI/ Soundstream , I'll being using the 3 way drivers, the tweeter and midrange from the PPI power, and the Midbass from the Soundstream RF3.6C.
Subwoofer - Soundstream R3.8, after actually holding one in my hand I can't think of a better sub to use for this build.. more details on it later.
DSP-processor- PPI Same as the SS Synth.. actually really doesn't matter which brand I use.
Coaxial - PPI
---------- Post added at 12:31 AM ---------- Previous post was at 12:31 AM ----------
Coaxial - PPI
Ok just something i wrote up trying to figure out amp selection... somewhat odd but I think this will work out well.
FRONT STAGE
(3) PPI TWEETERS,
(3) PPI MIDRANGE
(2) PPI MIDBASS
8 CHANNELS = 2 x REF4.400
REAR
(2) PPI Power Class
Bi- ampable. so
4 CHANNELS = 1 REF5.1000
SUBWOOFER
(4) R3. Soundstream Subwoofers OR RFW-8’s
1 CHANNEL = REF5.1000
Soo a total of 3 amps, 2 REF4.400's and 1 REF5.1000. It may be switched to 2 REF4.920's since they're the same length as the REF5., but they are also very large and I need to get a better idea with the area I'm working with. Plus I really dont need that much power on a front stage either but hey its bragging rights
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Anyone? Anyone? Looking at the audio control d 6.1200
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Excellent for good sound stage and imaging, don't expect it to move your mirrors or anything. Honestly with what you're trying to do just doing...
12
Farmacist
Soundstream Elite
Farmacist
Detroit, MI
customaudioman
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
