2012 Civic Si Build Log
  • 2
seg_representin
IL
Finally finished my build last weekend. Car is a 2012 Civic Si Sedan. I still have to fully deaden the doors, clean up the mess of wires in the trunk, and carpet the sub box. I'm doing a 2-way active front setup with no rear fill. The box will probably be just a temp box, just wanted to get some low end in quickly. On to the build....sorry if the pics aren't that great they were done off my phone.
Equipment:
Fronts: Sundown SA-6.5CS
Processor: Rockford Fosgate 3sixty.3
Subs: 2x PG RSD10's
Amp: Alpine PDX-V9
-Factory sheet read 129x4 and 570x1 for the sub channel
The car
Don't know what that red is on the right, but it must have been a reflection bc its not there on my car
Build Snack
Wood all cut (7-ply birch)
Doors all apart
Stock Speaker vs. Aftermarket
Fitting Speaker Adapter to door
Both adapters built and sealed with bin sealer primer
Window Sealer added around adapter to seal to door frame. Sealer was also added around speaker when attached to the door
Left and right speaker installed
Stock tweeter in the A-Pillar taken off
Aftermarket tweeter. Hot glued the front of the tweeter casing, really the only option i saw fit, and the glue can be peeled off if need be later
Headunit has differential signal output, so i had to tap into the stock harness
Speaker wires, rcas, 12v switched ran down opposite side of car
Box build (0.7 cubes sealed)
All hooked up
This looks really clean. Can you explain how you mounted and wired your tweeters? I have a '13 civic and will be replacing the fronts with Morel Maximo's. My only problem is since they have passive crossovers, I'll have to mount them in the door somewhere but I don't know how to get the tweeter wires down through the a-pillar, through the boot, and into the door. Did you have problems? Any advice? Thanks!
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
830
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
seg_representin
seg_representin
IL
chones
