2004 Mustang System..Need Help
  • 2
Nickg
10
Fresno
I have a few questions that i hope i can get some answers too. I currently have two 12" JL Audio w1v2's powered by a lightning audio s2.300.2 in a sealed box. I have a set of Eclipse sp5700 point source speakers in the front, and se8375 in the rear...my questions are..
1. Should i purchase a new amplifier for the subwoofers and use the s2.300.2 to power the coaxials al the way around...or look for a solid four channel instead?
2. Any amplifier suggestions?
3. For a entry level set up how does this seem overall?
Thanks i appreciate your time.
Use the amp for the front speakers. Run rears off head unit. Buy a new amp for the subs. I would get a good mono amp that will run the 2 subs with about 400w for them. Look into maybe a PG 400.1, they are around for good prices.
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
Nickg
Nickg
Fresno
Nickg
