2000 Grand Marquis Build
stilltippin863
Florida
right now i am just stacking up everything then i will do the install....this will be a slow process....
this is what i have so far....
Ia 40.1 amplifier
50ft Gray Stinger HPM wire
50 1/0 ring terminals
3 1/0 fuse holders with 250 amp fuses
2 pair of Stinger rca's
1 D34/78 yellow top optima (engine compartment)
2 D31T yellow top optimas with bud bars (in trunk)
New battery terminals
15ft 8ga wire (for subs)
Still need to buy :
Get box built
250 amp Alternator
i built the battery box yesterday....you can see it in the pictures....
also i cut a piece of wood to be the plat form of the amp and the battery box.....i am still thinking if i want to do something crazy for the amp ...or just mount it to the piece of wood.....but when i start adding stuff to the car i will post up the progress.....also for right now...i am leaving the mids setup i already have ....maybe later down the road i might up grade it...but it is loud enough for me....also i am leaveing head unit for the time being...will upgrade ....after i buy subs,box,and alternator
what i have for the mids setup is .....
1 6 inch earthquake in each front door......4 8in earthquakes in back deck with port hole....on a 1500watt 2 channel...audiofonice amp pushing them....jensen double din in-dash tv...also have a 15 inch flip down tv... in middle of headliner....
this is what it looked like with my 24's on it ...but i just sold them to build me a system....
oh yeah i also have train horns under bumper lol
i am really thinking Re audio's....i really love the re's...but have never heard..nightshades,re's any of that.....most what i have heard is kickers,fosgate,mmats,stuff like that
either
2 18 mt's
2 18 mx's
2 18 xxx.
i need 2 subs that will handle 4000k daily at .5ohm
fi btls were the loudest in my car 153 db
so ...you are saying i can fit 2 18 fi btl's in my trunk ported?? and if so would the 8c.f. box be able to fit in the bottom of trunk?? like not built up on the sides?? faceing up or toward the back?
2 18s would be a hard squeeze in there. Where did you get those pods for the door speakers? How did you get a double din in the dash? When I tried one in there it looked like it was hitting the air vents.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
stilltippin863
stilltippin863
Florida
stilltippin863
SPLBassJunkie
    May 21, 2024
    May 20, 2024
