basebalz13 10+ year member
D-money
1. Product: I have 2 RD D9's forsale. They are still like new now with MAYBE a total of a hour play time on them. The strongest and most favorite 5k board I got to play with. Tested these 2 against 2 500.1's and FIRST test was .6 higher that 500.1's. Didnt get any more time to test more so im sure there was more in it //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
2. Specs:
I clamped a true 49xx at 1.5 ohms and voltage 13.0 and 54xx at .94 ohms and voltage at 13.0
Features
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Heavy duty cooper layer double sided epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24 dB low pass (LPF) crossover variable
18 dB bass boost equalization control variable
180 degree variable adjustable phase shift
24 dB subsonic filter variable
Selectable Switch for MASTER and SLAVE Operation
Speaker short, over current, thermal, and DC protection circuit
RCA line input and line output
2 x 0 guage (AWG) battery input connectors
Efficiency: 86% at 4 ohm, 100 Hz
Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
Operating voltage: DC 10V ~ 18V power input
Damping factor: better 350 into 1 ohm
Wired remote controller
Specifications
RMS power, 2 ohm linkable/dual mono
RMS power, .75 ohms mono 5400
RMS power, 1 ohm mono 3600
RMS power, 2 ohm mono 1800
RMS power, 4 ohms mono 900
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500 amps
Input Sensitivity 200mV to 6V (+/- 5%)
3. Description/Condition:
1 is flawless, other has a nick on the aluminum bar.
4. Price: :
900 shipped each, 1700 for both.
5. Pictures:
2. Specs:
Features
Specifications
T.H.D @ 4 ohm
4. Price: :
5. Pictures:
