2 ohm and 4 ohm load question
  • 3
heyhi1
nyc
If i have a 5 channel amp
I want to power 2 4 ohm tweeters straight to 4 ohms on 2 channels
Then i have 4 4ohm door speakers wich im gonna run 2 of them in parralel on third channel and two of them in parallel on the 4th channel giving me 2 ohms per speaker
5th channel will be 2 ohm sub
The amp is rated 70 x4 @4 ohms and 300x1 @4 ohms
110x4 @2 ohms and 400x1 @ 2 ohms
Since im miss matching will each channel give me rated rms to each speaker? The first 2 channels with tweeters @4 ohms will i get 70rms?
And then the next 2 channels, each channel having 2 4 ohm speakers in parralel giving me 2 ohms. Will each speaker recieve the rated 110 rms even tho these 2 channels will be 2 ohms and not 4 like the tweets ?
And the sub will be 2 ohms.....will it give me 400 rms
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
5
599
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
404
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
heyhi1
heyhi1
nyc
n2audio
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
