2 Obsidian 18vs vs 1 DC XL18
  • 5
bgowdy
Heroes are remembered, but legends never die
Ok, so this may come as a funny thread. But there is some reason behind it.
The comparison behind it is this:
2 OA 18s vs 1 DC XL 18
2 18s:
-Smaller size enclosure for each(around 4.6 cube per sub)
-limited bracing/mass do to the amount of space
-single baffle all the way around
-running 3k at them(im pretty sure they will hold it)
1 DC XL-18:
-Will have plenty of room for Enclsoure
-Will have plenty of room for bracing/mass etc
-i have the space to double baffle enclosure
-running 3k at it(i know it will take it and some)
cheers and thanks
So what are you asking ?
which i would be better off with i guess. i can run the 2 18s in a, ill say maybe half decent box due to its size. Or i can run the 1 dc xl18(or another good 18) in box that i will have plenty of room to build, and brace and will be a good overall enclosure.
Do 4 12's in an 8 cube box with a **** ton of bracing and port area. Be louder than either choice. Ive read you had 2 15's before, 1 18 wont be as loud as that.
actually i had 1 18" hdc3 18 before the 2-15s and my single 18 was louder then the 15s.....
Well one sub in the correct size box will always be better than 2 subs in a inadequate box[/Q
seeing you sell XL's, i figure you know the ins & out of them. is there a magical amount of port that these like
You can always do sufficient bracing without taking up much volume. All thread doesn't give up much volume obviously, and fiber-glassing the inside of the enclosure
yea but without brace the enclosure is already smaller. i cant double baffle anything because im at my dimension maxs in each direction,
bgowdy
bgowdy
Campbellsville, Ky
bgowdy
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
