SOLD 2 aura 4 channel amps 1 400watts 1 280 watts
sancho20
i have 2 aura 4 channel amps couldnt find exact specs on them only the watts .looking to get $110 for the 400 watt and 80 for the 280 watt.From what ive heard they are very good amps and slightly under rated.I also have a ma audio 30 band eq for $65
I have one of the 400q-a's;when i worked for a car audio shop in Fla. we use to carry the aura line and the sales rep showed us actual power specs that were run @ 12.8 volts and the 400q-a did 100 x4 @ 4 ohms,160 x 4 @ 2 ohms and 320 x 2 @ 4 ohms bridged.It's a very clean sounding amp!
91
338
10
719
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
428
sancho20
sancho20
tampa bay ,florida
sancho20
    May 31, 2024
    May 24, 2024
