2 amps on one battery?
  • 3
beartoe
I currently have a 900w pioneer amp running my 2 comps. I have another pioneer amp (760w) that I'm not using but wanted to add to the battery to run 2 more sub's. I talked to a guy a a shop if I could do this and he said I would need a HOalt, another battery, and a bunch of other stuff if I wanted it to work and that my batt and alt couldn't handle another amp. Is this true or is he trying to sell me more stuff.
2010 ford focus with brand new oem apt
2 kicker comp 12s in ported box
900w pioneer amp with 4 (yes 4) fans on it
Any help would be appreciated
I asked this same question a few days ago but this is with new input from a "shop expert" so I figured I would ask it again
Yea If you already have a secondary battery in the back and a battery up front your good man. You have to get the same speakers you have now gotta be 12s and gotta be the same box. Tuned the same. eevrything. or build a box for 4 subs. I would recommend selling everything and buying new equipment. Those amps ****
I have a 2010 focus and you are good for around 1200rms with just the front battery. I would not recommend running 2 different amps and 2 different subs though.
You would be better off selling what you have and buying 2 good 12" subs and a good single amp for them.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
278
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
469
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
beartoe
beartoe
Baton Rouge,LA
winkychevelle
    May 24, 2024
