1997 Camry 2.2liter 4banger Alternator Upgrade
tuomas
Hey right now I have a stock alt, I'm lookin to upgrade it since the factory specs say its like 90A and its not really enough for what I'm trying to do. Anyone recommend where to get a new alt for it? I've looked around a bit but haven't found much for the camry alternator wise... any pointers?
Also, upgrading the alt I have one concern in mind and that is how much it will put out at idle. I'd really rather not have a dramatic change or audible change between when I'm driving and pull up to an intersection and start rolling again.
Please don't turn this into a "oh you don't need to upgrade your alt just do the big three" thread, I need powerZ!
http://stores.ebay.com/HI-AMPS-ALTERNATORS
they have a 180 amp for you. my 97 es300 uses the same alt as your car. this is also the only hi amp alt. sold for my as well as your car under like 400 bucks. and even though the seller looks pretty cheap, the alt. works amazing.
Not sure where you seen the 180 amp. All I found was this 160 amp
http://cgi.ebay.com/ebaymotors/94-2000-toyota-Rav4-camry-solara-160-Amps-Alternator_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el1262QQcategoryZ33573QQihZ022QQitemZ350100231751
Any thoughts on that one?? I'm sure it'd be better than my 90A alt w/ 193k miles on it.. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
I Might try to get one for my 89 in a month or 2. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
tuomas
tuomas
East SF Bay Area, CA
BushJ311
    May 24, 2024
