1992 Jeep Cherokee Laredo Radio went out
  • 1
95volvosx
Tampa, FL
I was driving the other day on the way from the casino and for some reason my radio blandly just went out. I took the faceplate off to see if maybe it was just hot and it was slightly warm, nothing out of the usual use of radios I've used before. It has not come back on and I've also noticed a couple other things stopped working on my car once that went out. My interior lighting on my car(not the gauges, just the lights on the roof) went out. And also the electronic feature of my automatic locks doesn't work from my control now, I am required to do it all manually. Also my passenger door stopped working on the inside but it still works from the outside, I think that's a different situation though which my brother will figure out for me. Anyways it's an older Eclipse after market head unit but if anybody can help me it'd be greatly appreciated. The fuse for the radio and my interior lights are good FYI.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
716
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
6
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
9K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
95volvosx
95volvosx
Tampa, FL
95volvosx
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
