150 db + 1998 Ford Escort zx2 Build log
18 you better get it! it takes alot of time to get it right. i hate doing stuff twice so i just take twice as long the first time so i dont have to redo it lol. or at least try to.
im at 146.7 tuned at 33 in 8 cubes. Still trying to figure out the optimal size enclosure and tuning to get to 150...i wish i had a TL //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
33 htz? thats a good score. just make a port plug and tune it higher for spl and ull get there no problem
you know, i never thought of doing that //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif lol. Ive been meaning to ask you, have you metered your setup tuned for music?
i was just thinking, i don't know if a plug would work or not, since my slot port is in the shape of a L in the box...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
aero port plug then. on music at 1.4 ohms (1k rms) and 32 htz it burps 145s but musics only like 143.xx if i had the electrical to bassrace on .35 i could probly BR around 147s or so
COUPLE RANDOM PICS
hole cutout for the sub, pretty round for cutting with a jigsaw on both baffles //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
doubled up 12g wire for the inside of the box wires, going to upgrade to 8g before new reconed sub goes back in
jumpers with 8g wire in them. this is one of the best ideas i have ever got introduced to.
sundown 3500 on a lvl5 18 adn only 146 somthing is wrong there
honestly it should be a little more i think too...i have not messed with my settings at all yet...have been way to busy with work and school. I know i need to find out where i peak at so i can burp it and not play a sweep. Im confident if i could set the gains good and burp it, i could hit 148ish
nevermind ur port isnt wide enough to do a port plug. mines 8 inches wide so thats why i can do that lol. just cut some of the L on the port off to tune it higher. also put a all thread or dowel rod in the box for bracing. if that was almost finished u need bracing for sure. mine needs bracing and i only have 1k rms for daily and it still needs some
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
697
I wouldnt spend the funds on that amp if you have no way of knowing it works or not. Id purchase another 4 ch for that kind of money. You just...
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
I'm finally getting back into building a system after many years. I figure I'll document what I do. Here's my truck I initially wanted just a...
Has anyone bought/used a pre-fab underseat F150 SuperCrew sub box in a SUPER-CAB? 2015-2020 in particular I know the super crew seats are...
basscort2009
Banned
basscort2009
dallas tx
zack1442
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
