130+ DB system help
Bass Infection
Wisconsin
I want to make a 140+ DB system for $1000 or less, this is with wires/sub(s)/amp i also want some SQ as it will be a daily driver, not just a burp box. Also, I have been looking at RE audio SEx 12" would these be able to push 140+? I would prefer two twelves
That should be easily attainable. Off the top of the head get a pair of AQ SDC's and a AQ 1200 and you'd be well over 130 in the right box.
Or you could go with maybe DC lvl 3's or Fi Q 18.
How much room do you have?
I have a 2001 dodge stratus, but I would probably fold down the back seats and face the subs towards the front of the car. I would prefer to push around 150 db if possible
So you could probably do a pair of 12"s, with the port off to one side.
the difference between 130 and 150 is ridiculous!
x2 on that.
You'd have to do quite a bit of work to get around 150. 140 could be attainable if you burped it, but probably not on music with 1000 dollar budget.
x2 on that.
I would prefer 12" subs actually, what do you have in mind?
x2 on that.
I've done over 140 with music on 450 dollars
  • Locked
Looking to buy these sir! Pm me - I requested you on IG
5
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
326
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
671
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
Bass Infection
Bass Infection
Wisconsin
Bass Infection
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
