1 sub 2 speakers vs 4 speakers
Johnniz
15
Oslo
Hi.
Im going to make a simple speaker enclosure to have in my boat. I dont want to spend too much money and also only have the one battery (60amp car battery).
I have a cheap 500w 4 channel  amp from Kenwood (KAC-6405) with these ratings: 4x40W@ 4 ohms and 130w x 2 bridged.
Would you guys choose
A: 2 larger speakers, like 6,5 or 8 inch close to 100W RMS each?
B: 2 smaller speakers, maybe 4 or 5 inch closer to 40-50W RMS each and a small sub close to 100W RMS?
C 4 smaller speakers, all 40-50W RMS
Its a 14ft boat, and I was planning to have the enclosure under the deck in front.
Thanks
If this is going to be up top with all the wind, waves, and engine noise, I'd go with the two larger full range speakers if you only want one mounting location. 4 speakers would be ok if you installed them front and rear.
Hi.
Thanks
this 8 gets loud with good sensitivity ratings and SQ, plays up really high as well into tweeter territory. You want to bridge your amp to a pair of these.
https://www.amazon.com/PRV-8MB500v2-NDY-Neodymium-Midbass-Midrange/dp/B072YNDVP1
for a boat?....
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
585
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
You can use two front channels to power the full range speakers, then use the rear channels to power a sub. IMO, for that price I would rather use...
Johnniz
Johnniz
Oslo
Johnniz
    Jun 1, 2024
    May 31, 2024
