1 ohm help!!!!!!
  • 5
I want to get two orion 2ohm 10" subs rated at a total of 3000w rms and I hifonics amp rated at 2600w rms @ 1ohm. How do I wire the amp to run at 1 ohm or how much rms power does an amp have to be to power these subs? Thanks.
well just being about 400 watts under isnt too bad you coukd do that. If the 2 orion subs are svc 2ohm then u can jus wire them parallel to get a 1ohm load. If they're dvc 2ohm then you can only wire them to either a .5ohm load or a 2ohm load.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
5
719
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
517
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
dking_boss
dking_boss
Sierra Vista, AZ
infamous_e46
