1.8 ohm impedance fine on 2 ohm nominal amps?
  • 2
Maxchaos
CarAudio.com Newbie
8
Italy
Hello,I'm having a hard time figuring out this.
I have 8 speaker connected on my amp,currently a Stetsom ex3000eq 1 ohm.I'm planning to upgrade it to a 3500 2 ohm to get the most out of it.
The speakers are all 4 ohm.I've connected the 4 speakers per side in parallel,so I get almost 1 ohm per 4 woofers.
Then I write the 2 doors in series,to get 1ohm+1ohm=2ohm NOMINAL at the amplifier wires.
The question is,the measured impedance of every woofer is 3.4 ohm,and after the connection I get 1.7-1.8 ohms.
Can I use a brazilian amp rated for minimum 2 ohm loads? Or do i need to get the 1 ohm to get everything working?
I don't want to waste money on a new amp if it will protect/burn itself,because the real impedance measured is lower than the nominal :(
It also lowers the amps efficiency and raises the current draw.
5
588
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
396
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
Maxchaos
CarAudio.com Newbie
Maxchaos
Italy
Maxchaos
winkychevelle
    May 24, 2024
