Southeast Region 1/31/10 Hialeah, FL dB Drag & bass Race 1X Event
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
ill be there watching. is this the same one as last year? is mike from CFSPL gonna be the judge?
I'm assuming it's the same show.. It's at Thunder Electronics again so probably. (At least I'm almost positive that's the address from Thunder)
i will try to go out there with the 350z
my boy kurt is bringing the blazer with 2 x 15" ia dp & 2 x saz 2k
my boy rick is bringing the integra with 2 x 12" rf and 2 x type rf amps
my boy Javier will bring his f350 with single 10" off a us amps merlin 1500 watts
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
225
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
429
Owners1
Owners1
Palm Beach Gardens, FL
350zspl
