SOLD 1/0 Big 3 Upgrade Kits Starting at $25!!!
scottiej
It's a shame I've got all this perfectly cut and terminated wire laying around and nobody is using it... here's how this works.
Pop your hood, and guestimate the lengths of the follow 3 cables:
1. Alt output to battery positive.
2. Battery negative to chassis.
3. Chassis to engine block.
An easy way to get a close measurement is to take a small piece of string or wire and lay it where the wire will go. Cut it with a pair of scissors to the length you need it to be. Do this once for each of the three cables above, and measure their length in inches.
Once you know the lengths you need, refer to the list at the bottom of this post and find the closest cable that will work for your installation. If you are in doubt, go with the next size up cable because you can always route the cable another way and tie it up out of the way. Some cars can be done for $25 or less plus a little bit of your time... some cars will take more.
Here are some pics...
Here is the list of available pieces...
Qty - Size (in.) - Color - Terminated - Price Ea.
28 - 7.25 - Yellow - 2 x 3/8" Ring with Red Jacket - $3.00
4 - 11 - Yellow - 2 x 3/8" Ring with Red Jacket - $5.00
11 - 7.25 - Silver - 2 x 3/8" Ring with Red Jacket - $3.00
3 - 24.5 - Silver - 2 x 3/8" Ring with Red Jacket - $6.00
13 - 24.5 - Silver - 2 x 3/8" Ring with Black Jacket - $6.00
3 - 28 - Silver - 2 x 3/8" Ring with Black Jacket - $7.00
18 - 34 - Silver - 2 x 3/8" Ring with Black Jacket - $9.00
1 - 38 - Silver - 2 x 3/8" Ring with Black Jacket - $9.00
1 - 40 - Silver - 2 x 3/8" Ring with Black Jacket - $10.00
5 - 42 - Silver - 2 x 3/8" Ring with Black Jacket - $10.50
8 - 44 - Silver - 2 x 3/8" Ring with Black Jacket - $11.00
8 - 54 - Silver - 2 x 3/8" Ring with Black Jacket - $13.50
3 - 64 - Silver - 2 x 3/8" Ring with Black Jacket - $16.00
5 - 73 - Silver - 2 x 3/8" Ring with Black Jacket - $18.25
27 - 41 - Silver - 1 x 3/8" Ring with Black Jacket - $10.25
21 - 50 - Silver - 1 x 3/8" Ring with Black Jacket - $12.50
1 - 21.5 - Red - 2 x 3/8" Ring with Red Jacket - $6.00
5 - 24.5 - Red - 2 x 3/8" Ring with Red Jacket - $6.00
1 - 28 - Red - 2 x 3/8" Ring with Red Jacket - $7.00
12 - 30 - Red - 2 x 3/8" Ring with Red Jacket - $7.00
3 - 32 - Red - 2 x 3/8" Ring with Red Jacket - $8.00
17 - 34 - Red - 2 x 3/8" Ring with Red Jacket - $9.00
5 - 42 - Red - 2 x 3/8" Ring with Red Jacket - $10.50
12 - 44 - Red - 2 x 3/8" Ring with Red Jacket - $11.00
3 - 48 - Red - 2 x 3/8" Ring with Red Jacket - $12.00
6 - 54 - Red - 2 x 3/8" Ring with Red Jacket - $13.50
3 - 64 - Red - 2 x 3/8" Ring with Red Jacket - $16.00
5 - 73 - Red - 2 x 3/8" Ring with Red Jacket - $18.25
4 - 38 - Red - 1 x 3/8" Ring with Red Jacket - $9.00
28 - 50 - Red - 1 x 3/8" Ring with Red Jacket - $12.50
1 - 64 - Red - N/A - $16.00
I will try to keep this list updated as frequently as possible so everyone will know what is remaining.
Let me know if anyone does a 2nd (95-01)gen explorer.. I will need to do big 3
I swear Im not lazy, right now wiring is just not on the top of the list and this is a nice deal.. I am to busy to try and go off post and find a HD or Lowes to buy a cheap tape
how much are flat rate boxes shipped to hawaii??? (96797)is it still flat rate?
I may be interested in a few wires...
Yep... flat rate applies! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Medium is $10.35 and Large is $13.95
Already need to update! Just sold 60ft!
4 - 54 - Silver - 2 x 3/8" Ring with Black Jacket - $13.50
17 - 50 - Silver - 1 x 3/8" Ring with Black Jacket - $12.50
5 - 54 - Red - 2 x 3/8" Ring with Red Jacket - $13.50
2 - 64 - Red - 2 x 3/8" Ring with Red Jacket - $16.00
24 - 50 - Red - 1 x 3/8" Ring with Red Jacket - $12.50
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
958
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
scottiej
scottiej
Knoxville, TN
mojo212
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
