07 Durango nav head unit replacement
  • 2
nitrodude
fl
Been out of car audio for a while now. Got a cheap Durango limited work truck with a dead navigation head unit.
Got a cheap double din radio and ordered a dash kit with a wiring harness.
Dash kit worked fine harness is wrong so I did some digging and apparently these trucks require an expensive programable adapter.
Kept digging and I found an amp bypass wiring harness. Looks like that would work and it's $30 vs $160. So I ordered that and just got it today.
Says in the instructions it has separate front tweeters and needs a crossover to work. And it has factory sub which won't work.
I don't care so much about the factory sub as eventually I'll probably get a sundown 8 or something for the back.
But I just want the damn stereo to work without costing an arm and a leg
So is there a small cheap crossover I can put behind the head unit?
Or is there an easier/cheaper way to go about this?  I'm not looking to spend a ton on this just wanted a cheap stereo that works lol
Well the head unit itself isn't that "cheap" it's a Sony xav-ax100 I just got it cheap.
I just want a way to get it hooked up to the factory speakers without costing a fortune. I'm not too concerned with it being the best sounding system in the world. Just want functional.
Hi all, The central entertainment screen in my 2009 Touareg (v6 TDI) stopped working yesterday. When I start the car I see the loading screen for...
6
450
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
731
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
783
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
nitrodude
nitrodude
fl
nitrodude
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
