0-600 and SB 1 or 2 CRX build
what is the advantage of having ports on the back of the box... I thought that was a big no-no
Its better than internal. Look at it this way. If you have an internal aero then you have a lot of dead space around the port opening that air can sit untill it is pushed out. If your port drops down from the top 12" then 11.9" down is all area that air can sit. With external, all of your air is forced through those ports because they are flush inside. does that make sense ?
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Nice scores man! wish i had a d5 to run 0-600 class....i wish they had a 600-1000 class...601-1800 is hard to compete in..lol
and what are you playing for street beat?? sounds like a steady tone the whole way through...
yes, 152 is a good score for that power. i am running a lot more power than what is allowed in that class. when i ran usaci i ran the 1800 watt pro class w/ 2 40.1s. i am running 4 40.1s now.
Forgive me for not being familiar with Usaci, but is a 152 a good score for 0-600?
yes...considering you have to use and amp rated under 600wrms @ 4ohm at 14.4v with only 1 extra batt...no modifications and has to be under window line and back seats have to be able to fold up and i believe you have to have stock alt as well...and a few other rules....but basically everything has to be able to be put in stock config...and then for 0-600 pro stock you can use two batts in the rear...iirc
so basically it's a competition to find an amp that will wire down the lowest and still rated at 600wrms@4ohm. like the d5 he is using or a cactus pf600, treo 4.1, couple of the mmats amps and db drive pd2000s are popular in this class...i think the record is a crx with 7-9 l7s on a cactus pf600 that hit 160+ in 08 i think
Not even close to what I need it to be. I am just starting this build and built a box that could be moved around easily. It was my first box and I have minimal time into testing (probably about 15 burps total). By the end of the season I hope to be much closer to, if not @ 160db on burps.
now that is metered in the kick and the door can be open. in my car the passenger kick is over 2 db higher than on the dash sealed.
My truck was 10db down from putting the meter on the windshield. 151 Outlaw gave me 141 sealed. The rex wont have as much of a loss.
I love hunter's truck...did he drag it yet?
and nice score //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
First night out testing it he put her down doing 50mph //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
4K
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
soundstreamer
Ω
soundstreamer
Farmington, NM
soundstreamer
