12 subwoofers
Any power that will work for subs picked
Just no shallow subs. Full size only
2500k budget . Going in a tundra
Any other info
Yall just keep gabbing about chains
Lighten up man, it's all in good fun.
Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why eliminate shallow mount subs? You came here for advice and there are some very good shallow mount subs on the market that may well perform quite admirably in a given application - ESPECIALLY in a truck.
That said, the "taco box" recommends the following:
Image Dynamics ID12D2
Image Dynamics ID12D4
Image Dynamics IDQ12D2
Image Dynamics IDQ12D4
Good subs that you know will fit and have already been tested.
The company is saying they don't recommend shallow mounts so I understand where you are getting that information. That said, just because they think that is the case doesn;t make it so. Could be that they don't like the the way the ID shallows play in their box, which makes sense given the size of the enclosure and the recommended 30hz tuning frequency.
Why not use the ID subs?
As for amplification (ID subs), you should be looking for something in the 700-1000 watt range. There are probably 8-10 that meet that criteria.
Keep in mind this is a prefab box you are going to use and not designed not conducive to 3000 watt, high powered systems.
These have a top mounting depth of 6"
2 of them would be significantly loud. they handle 800 watts ea. Pair them with something like this
There are many options to explore. 2 cubic feet per driver is a pretty good size. Do you know what the port displacement in this the box is? I'd find out and add it the stuff needed to help you figure out what works best.
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
Unfortunately, not doing the big three and putting another amp in is kinds of like putting the cart in front of the horse. But my latest go to...
chris bushneck
chris bushneck
South Carolina
    May 12, 2024
    May 11, 2024
