Do i need this
  • 2
Sinisterspawn
13
St.louis
Do I need the AudioControl LC2i with my AudioControl amps ?
Looks like it's already "in" the loop. Both those amps can take speaker level inputs so you didn't need it but I wouldn't pull it out now.
Unless you need a quick $50 - OR - you like many in here who, like myself, want to things a bit better in the "next" phase of the design. I like the board you made already, but if you take out the LOC, you could make it a straight across setup. I like clean and linear, but after investing in all the equipment, I like when EVERYTHING is out on display too!
144
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
449
346
754
Sinisterspawn
Sinisterspawn
St.louis
    May 16, 2024
    May 16, 2024
