Blackbrick 15" sub
  • 5
Looking at the pics, I can tell ya now those lead wires will be slapping the snot out of the cone 🤣
No no no, it was designed that way. As the sub breaks in, the coils burn off excess and become more prone to heating. The extra travel allows those temperature management prods to install new heat management vents on the back of the cone. Very high tech indeed.
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
497
531
629
Junior Member
Pharr, Texas
spokey9
    Jun 3, 2024
