Head unit flip out screen ?
Looking at the manual for that head unit it looks like the brown wire is the parking brake wire. Put a ring terminal on it and ground that wire and see if that works. If not, dunno.
I YouTube it and it said parking wire to ground wire. Done that and grounded it and still no working screen. Sending it back Friday. Thanks tho
That wire won't effect the screen. That parking brake wire is so that you can't mess with inputting navigation while driving, because it's too distracting. Even if that wire weren't grounded or working properly the rest of the head unit SHOULD work. That wire is not your problem.
Ok thanks. Everything works except the screen. I’m going to just send it back and they will replace it or refund me.
It seems i have one of those also, i almost forgot ....id have to double check tomorrow ..i may throw it in my Silverado. .Ive been wanting to...
287
633
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
719
terryracing86
terryracing86
missouri
Booger68
    May 24, 2024
    May 23, 2024
