SMD DD1+....Rental? Borrow? Buy new?
Many moons ago there was a guy on here who rented them. He is long gone. Find a Facebook car audio group near you and see if anyone has one.
If we were local I'd do it. Last time I used it, it was to check the head unit and a new amp. I use it to check for distortion, then set my amps to the actual wattage I want by AC voltage. Personally, I think they are more useful for head units than amps, (my last two kenwood head units, both made the full voltage at 34, and then had a 10% bump at the max 35 (where it's distorting).
The last amp I used it on was my alpine PDX-F6 which is rated 150w x4 @ 4ohm-<0.005% THD+N @ 1W, <0.05% THD+N @ rated power. It started distorting (the DD1 registers at 1% THD), so I thought I would use my multimeter to check the output. It was pushing out 440w per x4 @4ohm before distorting. That definitely would have blown my components, which I was only planning on 120w x 4.
I think at this point, I could just sell it since I just finished what is hopefully my last change to my daily build. They work and they are good, but are you looking for max output before distortion or do you have a target wattage you want to be at?
If I worked in a shop setting up systems every day I would probably have a dd-1, just for simplicity. But you can do the same thing with a $40 Oscilloscope.
Rentals wouldn't be bad you might even get a hit on DIYMA as well now and then.
  • Locked
COMPLETED SMD DD1
Money sent @DFS722
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
  • Locked
COMPLETED Smd vm-1
Looking to buy a smd vm-1
See the third sticky thread at the top of The Thunderdome? That was them. They ran this place in its hay-day.
18
MikeyD812
MikeyD812
Mitchell Indiana
JohnPD
Dan Medina
    Jun 17, 2024
    Jun 15, 2024
