Fuse blew. Need to find the correct fuse to use
Afandi55k
So I have a 800 watt amp and dual 10 subs and I want to change the amp to CT Sounds 1400 watt mono amp. My fuse blew so I wanted to change the amp as well as the fuse. Can anyone help me find which fuse I need to use that connected near the cars battery ? I am not sure which gauge of wire is used, but just by looking at it I believe it is 0 gauge ? It’s the most common size, the car was already wired from previous owner. Can anyone here help me find the right fuse to use ? Any help/recommendations would be greatly appreciated!! Thanks
Anl is common for larger wire. There are a lot of different types of fuses.
Hold the fuse in your hand and google audio fuses. You’ll find it or maybe decide to get the right one if the one you have isn’t ideal for your setup. Chances are you’ll want to go up in amperage if the other one blew. Disconnect your battery too whilst you’re working on the electrical stuff.
So I have a 800 watt amp and dual 10 subs and I went to change the amp to CT Sounds 1400 watt mono amp. My fuse blew so I wanted to change the amp as well as the fuse. Can anyone help me find which fuse I need to use that connected near the cars battery ? I am not sure which gauge of wire is used, but just by looking at it I believe it is 0 gauge ? It’s the most common size, the car was already wired from previous owner. Can anyone here help me find the right fuse to use ? Any help/recommendations would be greatly appreciated!! Thanks
You really need to know the gauge of the wire. If you fuse for 0 gauge and it's really 4 awg, you risk a serious wire fire. Also dose the amp have it's own fuse?
Hard to Guess.A pic of the wiring 2 the battery and @ the amplifier connection will help.
I should have posted them to begin with. I uploaded them, so that amp in the pic is my old one. I want to install this amp here
but need to know which fuse size to use and if I need to replace the wiring or not.
I am not sure if the amp has its own fuse, this is the amp I want to replace my old one with. Here’s the link.
The amp requires a 180amp outboard fuse. You need 0awg with a 180 amp fuse at the battery. If you fuse 4awg at 180amps you risk a wire fire as the fuse will pass more current than the wire can handle.
One of my amps recommends 100 A and the other 60 A so I fuse for 160 A near the battery. Then at the power distribution block you fuse each amp separately so 100 A and 60 A.
Fuse the wire near the battery based on its carrying capacity to protect the wire from failure...then the correct sized fuse to each amp
I think it's only one amp, and OP wants to replace the one amp. (This is if its only one amp).
That ct sounds amp has a 180amp fuse. (its also 1800w at 14.4v. 1400w is at 13.2, but that's not what your voltage is when running).
That red wire says 4ga on it. 4gauge / 4awg. That is too small for that new amp.
For the CT amp, you need to replace the power and ground wire with 1/0 OFC cables, and you can fuse near the battery at 180 amps. If the power cable is less than 15 feet, you could also use a 200amp fuse near the battery if that is your only option, (180 is better though). (If it's longer than 15ft you might be able to go higher, but we would be getting into a gray area where we would need more info).
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
624
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
Afandi55k
Afandi55k
Los Angeles California
spokey9
    May 18, 2024
    May 18, 2024
