I need some help tuning my amps with a oscilloscope
Im quite sure that I'm not using 10x but I don't really know, I only borrowed the oscilloscope from a friend.
If you see exactly 1/10 of what you expect to see, it's worth checking. See my attached picture. There is a slider switch on every probe I've used.
I dont have that slider but I got this menu and I think that it is the same
I've never used a digital scope, so I don't know what those settings should be. Are you confident that all settings are correct? Should we suspect scope settings or rule that out?
Edit: i have never used a power analyzer, but I suspect it gives different info than an oscilloscope, and that's why your reading is off. Connect it to a known voltage such as your battery or 120 outlet if it can read that high.
I connected it to the battery and I was 12 volts as it should. But I had it set for DC to check the battery and AC to check the rca cable
Are you having some sort of issue with the signal - ie amp isn't getting as loud as expected? Sometimes things just don't read properly. I just spend the afternoon troubleshooting my sprinkler system. 24vdc AC/DC converter read 1.3vdc. The trigger lines to the sprinkler valves should have read 24vdc too, but came in at 800mvdc. Same DMM read 120vac out of the outlet, read 24vdc off another ac/dc converter, read 3vdc on a remote control. The sprinkler system is still working even though it allegedly only has ~1vdc. :unsure:
The rca is suppose to have ~2 vac before clipping but my HU is only producing 0.2 vac clean before clipping.
Edit: there is coming sound out of the sub and speakers I just want to know how much I can tune it before it's clipping
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
Thank you it sounds way better then it was And I fixed why it was cutting off it was because of bad power because the full range amp was losing...
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
174
Snuskgamer
Snuskgamer
Sweden
Jimi77
chillin
    Jun 14, 2024
