American bass vfl comp1k smoking
Without better photos it's hard to really see anything. Based off of those it looks just fine.
Grab a digital multimeter, set it to continuity check (audible beep) and check for continuity between gate, drain, and source legs of all mosfets. Keep in mind that occasionally there will be a beep that will go away after a few seconds. That's normal as you're charging a cap somewhere in the circuit.
Smoking usually indicates a power supply fault so it's best to check there.
Also don't freak out when the rectifier diodes show continuity, that's normal.
  • Locked
Great amp. Ran on nothing lower than 13.9 volts ever. Adult owned and never abused. Looks: 8 of 10. A few scratches due to being used...
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
Thomas@scottsmobile
Thomas@scottsmobile
Jeffersonville Indiana
Bumpin' Yota
    May 24, 2024
