250 amp or 320 amp alternator
  • 2
2800w + 2000w =4800w.
x .85% efficiency (which is a rough guess) = 5,647w
5647w / 14.4v = 392 amps.
Thats when it's hitting hard and playing at max. The rest of the time, between it is charging at a rate higher than it is using. If you don't play it on full, and don't listen to medium heavy bass, and don't listen to it for more than an hour at a time, with a little shut off time before you turn the vehicle off to make sure you recharged, you could probably get away with 250. I would definitely go 320 on that so I wouldn't be limited.
That power is just your stereo. You also have the rest of your vehicle. Ecu, fans, and AC are big energy users, if you use those often. Injectors, lights, turns, anything that connects to your dash uses something. If you've added any lights, if you want to add another amp, or change one of them. If you want to charge a couple phones, an inverter, a screen, etc.. Just seems an easy answer to buy the 320, and not be limited right away. I would definitely go 320 with that. I'm at 240 and half that, because I wanted some room.
Personally, electrical is the one thing, if you are going to upgrade it, IT'S DEFINITELY WORTH THE MINIMAL PRICE INCREASE, to upgrade to what you MIGHT need, and not just what you need now.
It also depends on which amp you get. I drive a manual transmission so I can control my rev, and keep it up if I need to, to charge. In an automatic, you might be cruising at a low RPM, and you won't be charging at max amperage. If you are near idle, you won't get anywhere near full charge. That 240/320 alt charge is when you are usually around 2k RPMS on a great alt, and over 3K rpms on a crappy alt. Where do you cruise at? What rpm do you usually drive at? You should factor that in too.
2 or 3
849
I was going to run those same Jbl's before I went insane about the car. Glad I would've made a good choice.
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG,16.2022 @9PM CT THANKS
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
216
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
yobertss
yobertss
hawaii
yobertss
    Jun 15, 2024
    Jun 15, 2024
