New aftermarket radio resets everytime.
lapanje
I have Peugeot 406 2003 and recently upgraded factory car radio with Sony DSX-A410BT. I have used the adapter that came with the radio and everything works great but it resets everytime I turn it off and on so I have to connect it to bluetooth again everytime. I took some pictures of wiring. I would really appreciate any help.
[Pictures of radio](https://imgur.com/a/UHIJGzH)
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
700
You cant go wrong by adding anything to improve sound quality
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
861
lapanje
lapanje
Slovenia
