Too big ?
Box size is very important in subwoofer performance. Not only that, the box port area may be too big and cause your subs to go beyond their mechanical limit. Those subs were originally designed for sealed enclosures, so I suggest plugging the port and feel them out.
That *****! I only bought them because JL site says they can be used in sealed or ported enclosures. I used them in a ported enclosure prior to this in a smaller box but it was in a different vehicle.
What I meant is they were originally designed for sealed, but after further research, JL updated them for ported as well. Look at the JL site and maybe you could modify the box. Making it internally smaller just requires filling it with solid wood; it is the port size that will take some ingenuity.
Yeah I know what you meant… the censored word in my last comment was s u x. It wasn’t anything towards you it was the situation lol. I really appreciate you all for you input and direction! Glad I found this forum
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
5thGenFatboy
5thGenFatboy
NC
5thGenFatboy
