Can i wire two 2ohm subs to 2 ohm if wired seperatly on strapped amps
Bass so loud it HZ
Ok so i currently have two jp 23s strapped.im getting ready to ordrr two 18 inch resilient sound plats .ik i will need more power but plan on running it like this for a min till i can afford a bigger amp .im thinking about getting the dual 2 ohm so i can wire down to half ohm later down the road but if i were to keep my jp23s strapped and wire seperatly to each sub at 1 ohm that would would that give me 2 ohms or would that be the same thing as wiring them together .TIA
Do not quote me on this, but the way I understand it is that when the amps are set to Slave/Master mode, only the positives put out power. So you should not be able to wire one sub to each amp. If each amp's lowest Ohm setting is 1 Ohm, then in strapped/daisychained mode, you can only go 2 Ohms minimum. Just like a 2 channel in bridged mode. Your user manual should have all that pertinentt info.
Alright i appreciate it .i realize that i can just wire them to 2 ohm .i was thinking i could only do .5 and 4 ohm so i ended up ordering some dual 2 ohm and getting a bigger .5 ohm amp to feed them . The two j23s will not be enough
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
422
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
854
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
843
Bass so loud it HZ
Bass so loud it HZ
IN, United States
hispls
    May 8, 2024
    May 8, 2024
