Stereo integrity crossover settings
Jimg
217
13
What would be a good starting point for crossover settings
subs Rockford fosgate 8 inch
stereo integrity tm65.
stereo integrity M3 carbon
stereo integrity m25 tweeter
what range and slope would you start with on each speaker?
running active with a zapco dspz8
tm65: 80-500
M3: 500-2500hz
m25: 2500hz
Usually steepest available slope works best, but really you've got to play with aiming location and crossover points to get best results.
While we call the M3 Carbon our midrange it is actually a wideband loudspeaker capable of playing from 125 Hz up to 20,000 Hz. We recommend a highpass crossover point equal to or greater than 300 Hz with a 24 dB/octave slope.
tm-65 @ 80 Hz 12 dB
M3 @ 300 Hz 24 dB
M-25 @ 6 kHz 24 dB
All the components(though I think the tweeters are oos) the sql10 and matching passive radiators are on discounted preorder too
Those pair of 12s with the right enclosure and tuned as well as powered properly should perform much better than the single 15, provided you have...
  • Locked
Well I think mounting depth with be shorter on the BM 11, and of course surface area is more on the MKV 12. The 11 is more of a niche driver than...
Jimg
Jimg
