6x9 to 8 inch
Pimenteljoe
Canada
Hey guys well I’m curious if it’s possible, is it even doable to put in 8 inch speakers into the area of the 2019 Dodge Ram Limited.
The speakers I’ll use are Hertz SPL mids or woofers.
Now the both have a mounting depth of 2.5 to 3.3
I also know that I’ll need to use a custom bracket. But I just wanted to know if it’s even possible? Please let me know
So my real question is, is there enough room from the door panel that will not interfere with the speaker and have enough space for modifications.
8" speakers would require cutting a circle out of your mounting and would likely need to fabricate mounting. I suggest buying 6x9 to 6.5 and 1 inch tweeter, they are plastic pieces that cover the 6x9 hole and then give you a 6.5 hole and a 1" tweeter hole, but you can leave that empty. If you really want an 8 then order a speaker pod and try your best to make it look nice. Here is a link to the 6x9 adapter https://www.amazon.com/dp/B08L9LJZMY/?tag=caraudiocom-20
Thanks for the insight, my main goal is to install the hertz 8 inch spl speakers. I’m aware that I’ll need a bracket but my only concern was the distance from the door to the panel.
Measure your available space, buy or fabricate your adapter. I had the same issue fitting speakers in a shallow space to replace the factory ones. (I used cheap cutting boards from Walmart to fabricate my brackets), and look for speaker specifications that will fit your need.
I have an extra pair of these, NIB, $100 shipped!
14
Excellent!! Looks to be in tact. It will be a workhorse for you man
40
5K
Might be time to try something new as it sounds like it is the limitaion of the speakers. I’m not in the habit of recommending JBL but a buddy of...
40
5K
This is still a very nice Deal package for an entry level amp set up for some quality amps for the money...
18
If the JLs are not entry level, then do not torture yourself, just go for it. You already enjoyed those DS18s. In case you do not like them, the...
Pimenteljoe
Pimenteljoe
Canada
huberoy123
    May 24, 2024
    May 23, 2024
