Blaupunkt
What 10" sub? Model and make? Ohm value
Here are the specs of the sub I was looking at.
  • Rockville RMW8P 8" 800 Watt Car Subwoofer + Tunnel Slot Ported Sub Enclosure Box
  • 8” High power long excursion tuned subwoofer
  • CEA Power Rated 200 Watts / 400 Watts RMS / 800 Watts Peak
  • 1.5” high temperature 4 layer Kapton voice coil
  • 70 oz magnet structure weight
  • Talc filled polypropylene molded cone
  • Linear progressive spider suspension
  • Stitched to cone double laminated surround
  • Extended pole piece technology
  • Construction: CNC-Cut High-Grade MDF
  • Steel mesh grill
  • Recommended amplifier power: 200W- 400Wrms
  • Nominal Impedance: 4 Ohm
  • Steel mesh grill
Lookslike the amplifiers recommended should work just fine with Either Chs 1&2 or 3&4 bridged/mono mode/LPF should work just fine as well as using the other 2 chs on the 6x9s as well.
thnaks again I could not find this product in europe so I will go with this one ...
flyfishing
flyfishing
Orange County
    May 18, 2024
    May 16, 2024
