Adding tweeters to existing speakers inputs?
51 Chevy
It wanted to add 2 pair of extra tweeters 1 set front and 1 set back back. I already have 2 /4 ohm speakers ganged up on an A/D/S PS5;which can handle the 2 ohms fine ,had it that way for years on my old car. If I add tweeters also will this put to much strain on the amp, or cause tweeters don’t demand much power would it be ok.? Thanks
Looks like you have a small mid and tweeter already....
Yes, Those are 1 set of what I want to hook up. Polk mid/ Tweets,fronts would be Boston Acoustic Tweets only . Old School. The Polks aren’t hooked up yet. I believe I had it this way before in my 51 Chevy Truck for years just fine. Now I’m putting the system into a ML320 and can’t remember.
Ive had those Polk tweet and Mid Combo set up back in 90 I believe. Ive been looking for a set forever..I the 3 way set up along with the woofer 5.25 and I believe it came with a crossover? Cant remember.I had that system installed due to working all the time. But had them on a Concord/JBL GTQ 400 with some JBL GTQ 6.5s in rear doors with (4) of the T102 bazookas in the trunk of an 87 Accord on a Concord HU with a Hercules VII, and had a Concord CA 50.2 on some other set of 6.5 JBLs in the front doors with a JBL 3 way external Xover. Those Polks sound really nice. I would run them on their own Channels @ 4ohms if at all possible and not run the risk running them with another 4 ohm tweeter 2 ohms at a higher freq, as the mid will not perform correctly.Amps always run harder and run warmer at a lower Ohm load as well. If you do decide to run at 2 ohms.. I would make sure you have some Xovers to keep the proper low freq. out of the mix. I dont remember if those Polkshave an Xover for the tweets.? I would still recommend one for the mid regardless
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
835
Thanks. That makes sense. It sounds pretty good as is.
51 Chevy
51 Chevy
Mason city Iowa
Decebal
    Jun 10, 2024
