Speakers buzzing help?
L.V
Nevada
Would it be my amp is dying?
Ive had it for 4 years (machete 80.4)
The speakers buzz at any volume, any mode (AM/FM bluetooth, USB) I have done the big 3 upgrade. All wires are OFC wire from amps to speakers. The sub is just fine but all channels off the 4channel amp buzz.
Heres the kicker and what I cant find an answer to. The buzzing completely stops when its on LPF setting… HPF or Lp/Hp filters the buzzing comes back.
Try removing the rca cables from the amplifier and then turning it on. If the noise goes away, it is not the amplifier or speaker wiring, and you have a head unit or rca wiring problem.
If the noise is still there without the rcas connected, then the amplifier, or wiring is bad.
The buzz does go away when i disconnect the RCAs.
One thing that is also making no sense. When putting pressure on the gain adjustment knobs or any subsequent adjustments on the amp. The buzz will increase or decrease, again just pressing or wiggling the knobs and not turning will change the severity of the buzz. Any ideas?
Seen that before. My guess is the connection/s between the preamp/input board and the main board are failing.
If you are having that kind of issue with noise when tuning.. and If the amplifier is still under warranty.. Id send it back for a replacement or repair. If not .. get some can air and spray to tuning pods and work them up and down several times. Sometimes it helps get dust ect cleared out. But May need to be replaced on the board
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
365
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
261
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
404
L.V
L.V
Nevada
