Connecting DAP to DSP
  • 2
Me@e
KL
Hi đź‘‹,
I recently bought a R5 Gen 2 and wishes to connect to my Helix MK3 however I met into these issue not sure anyone here is having the same issue.
I did bought the Helix HEC Audio n install. But I can’t figure out where to set the volume.anyone can help as I’m kind of mee to this DAP
Lastly how or where can I find a 5m type C to mini usb.
Hi đź‘‹,
Pretty sure most people using daps straight into the helix processors are using the coax out or the 3.5mm anolog output.
And I believe you need the external controller to control the volume of the direct inputs.
As far as the mini USB to USBC I'd look at Amazon. I prefer Anker cords personally but at 5m audio quest might be one of your only options
30secs of looking on Amazon
Hi @winkychevelle
thanks 🙏 but I guess I have used up all inputs as I am running on 3 way so I left with the 3.5mm will look into it with the control.
much appreciate for the time on your search đź‘€ will get them now
The reason for that is power comes from the reverse bulb wire and not all cars have OEM reverse camera. Does the red wire coming out of the...
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
924
Thank you for the help. Now I finally understood :) Bass working fine now :) Life back to music ;)
Me@e
Me@e
KL
Me@e
