COMPLETED Custom subwoofers and some parts.
  • 2
djdilliodon!
760
NY
Price
$1
Condition (1 worst - 10 best)
This is the last of what I have left. Need this all gone asap! All prices include shipping! I have this stuff listed elsewhere so first come first served!
Custom built tc sounds 3HP 15” in dual 2 ohm. Motor has been fully refreshed and it has a brand new Ti frame. New linear roll nomex spiders with dual sewn leads, 3” precision econo wind CCA wire coil with high temp black coating, aramid sheet wrapped collar, and black anodized aluminum former. Frame to motor spacers to bring volcano top in line with frame for maximum clearance. Pressed Kraft pulp cone with Kevlar strand blend and super tall roll rubberized foam surrounds and dual stitching. Dry carbon fiber dust cap. Direct 8 ga leads. Will easily handle 1500w rms and has over 38mm of one way xmax. Will do perfectly in 2.5-3 cubic feet sealed or 3.25-3.75 cubic feet ported. $365 shipped! Last one I have and won’t be building anymore anytime soon.
Custom 15” in dual 2 ohm built for testing purposes. Triple stacked Y35 motor that is 50 pounds by itself. Radially drilled back plate with pole vented. 3” custom made precision econo wind voice coil with aluminum flat wire, aramid sheet collar, black anodized aluminum former, black high temp coating, multi layer nomex spiders with triple sewn flat leads, 8ga direct leads, motor to frame spacers, Ti frame, non pressed Kraft pulp Kevlar strand blend cone with mega roll rubberized foam surround with dual stitching. Solid gloss carbon fiber dust cap. 2000w rms and over 30mm of xmax. Will work in sealed from 2.75-3.25 cubic feet and ported from 3.5-4.25 cubic feet. Sub is mint!! Motor has light marks and a little glue smear on it. $375 shipped, sub weights 55 pounds!
Custom 15” in dual 2 ohm. Dry carbon dust cap, precision econo wind custom coil with copper wire, aluminum former, aramid sheet wrapped collar, non pressed kraft pulp cone with blended Kevlar strands and tall rubberized foam surround. Triple stack Y35 motor with radially drilled back plate and pole vent, 8 ga direct leads, 12 spoke cast frame, linear roll spiders with dual sewn leads, 1000-1200w rms. Very efficient sub and will work excellent in 2.4-3 cubic feet sealed, or 3.25-3.75 cubic feet ported. 25mm of xmax, nothing will touch it for the cash! Used for testing only, glue smear on cone but nothing that affects the performance! $250 shipped!
Skar EVL motor with spacer/cooling plates, for 3” coils, 5” x 6 bolt pattern $75 shipped
American bass HD15 dual 1 ohm custom voice coil. Made by precision econo wind. Black anodized aluminum former, aluminum flat wire with black high temp coating, aramid sheet wrapped collar. 3.336” ID and 3.527” OD. Former height is 6”. Winding with is slightly increased for more xmax. Will easily take 2000-2500w rms. I’ve did rebuilds on these subs many times and had this custom made. I’m too busy doing full custom builds so currently not doing recones. $75 shipped and I’ll throw in a 10” OD 3 layer nomex spider. The opening is larger than the coil so it will have to be tacked in place and then filled in with glue to build it out. Not hard to do. This combo on these is amazing in ported setups!
If you would like pics of anything specifically just let me know!
Was Photo Included
  1. Yes
First sub in pics is all that is left. First $225 shipped gets it!
Any parts left?
I have the coil left that would work on an American bass HD 15 or anything else with a gap that will fit it and a 10” diameter spider for a 3.5” coil in 3 layer nomex with dual sewn leads. This spider will take gap filling if used with this coil but fits the w7 size coils. I use to use these spiders when taking trades on W7 motors but don’t really use those motors anymore.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
djdilliodon!
djdilliodon!
NY
LFR
    May 31, 2024
    May 24, 2024
