So I've got my lithium bank assembled and I'm working on getting the front battery out and everything mounted.
Currently I have a single run of Knukonceptz Kholosus 1/0 to the back, once everything is installed it will be about 10 feet of cable from the distribution block up front to the bank behind the drivers seat. It's a little hard to measure exactly, but 10 feet is the absolute max length.
I've got the big 3(technically 4 on my car) done, and a very solid chassis ground in the back. I will not be getting a giant alternator for the time being, but I do intend to put in a 200a alt or higher in the future. Currently my charging voltage directly at the alt is 14.582v cold and I'm reading 14.534v at the distribution blocks in the rear.
With my run being so short can I get away with the single 1/0 or do I really need to add another run?
Mqtt
Mqtt
