How big?
  • 2
spokey9
5 time International Booty Bandit Gold Meldalist
5,043
1,884
NE AR
So my battery shop said they can set me up safely with a second battery...so how big do I need to go on my 2nd battery...I want an agm and the system will be a taramps smart 5k, 2 ssa 15" icons plus a kicker cxa360.4 on mids/high...I don't play my stereo with the key off and I primarily listen to it on my commute to and from work (about an hour a day) with the occasional weekend drive for about 2hrs).
My electrical has been done...320 alt, big 3 in 1/0 ofc, my power run are 1/0 ofc same with my ground
So I'm planning on installing a Smart 5 down the line and I have a 250 alt, big 3 with 2/0 ofc, 60ah AGM under the hood and 100ah AGM in the rear.
I was told that was overkill for 5k and was more for 6-7.5 k. If you put a 100ah AGM as well your electrical would pretty much match mine with a faster charge time.
Given that I'd say a 50-60 to be safe. A little overkill never hurts IMHO. It's better to be way over than even a little under.
Hope that helps.
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
spokey9
spokey9
NE AR
Original wis
    Jun 15, 2024
    Jun 15, 2024
