2.7 ohm, 3 sub setup questions.
Since you think you know everything, please explain to me how, when I say that I want an amp that will put out 1800 watts RMS at 2.7ohms, you think the answer is an amp that puts out 2,000 watts at 2.0 ohms, and 3,000 watts at 4ohms. You're not even doing basic math. Even on your own example you some how don't realize that would be somewhere around 30% more than what I want, and then your reasoning is to turn down the gain, (which has nothing to do with wattage).
Idk what you want. You have 3 600w rms subs 3×600=1800w I did the formula off of that. Don't want 1800w adjust the numbers in the formula.
You asked for the formula here it is
V(ac)=√(w×r)
The DD1 is to set the gain. You don't even get how your two paragraphs in the same comment contradict each other. If setting the gain below its nominal setting, still makes rated power, THEN "HOW IT WOULD ACT LIKE A POWER KNOB"?
This is wrong setting the gain below the nominal would not allow it to make rated power. That's why it acts like a power knob BELOW that point.
Bud I was trying to help. Gave you the best advice possible. If you don't know how the gain knob works then learn because the gain infact raises output voltage until it reaches maximum output. So yes if you lower the gain you lower the output voltage.
What you are saying makes no sense at all. You think it does, but youre just looking like a fool.
I'm not responding anymore as I've given you all the help I can
V(ac)=√(w×r)
Wow you are a jackazz. You said it effects "sensitivity" and that is wrong. It does increase voltage like I said it does. What I was wrong about was that I was thinking it increases the voltage then sends the wattage, but it multiplies it. That was it.
Then the two you turned this into an azzhole competition because I thought it added and not multiplied. All this nonsense for what?? Screw you both.
So you were wrong but we are the ******** for telling you that you were wrong...
You fit in perfectly here....
:ROFLMAO::ROFLMAO::ROFLMAO:
I was wrong because I had the HOW wrong.
He was wrong for the way he worded it.
You were wrong for being nothing but a troll.
We were all wrong for increasing the jackassery.
No, I don't NEED to try to help people in here. I answered a few other threads while I was trying to get help, (tried to give a little to get a little). That was too much to handle for you.
I've got a feeling the two of you are young kids (probably in your 30s). No kids, no house, no roots. You seem to have no concept of community. That's what this and other forums like this should be. There's a ridiculous amount of insecurity in all aspects of the car world. Many want to help, and many don't want others to have what they have, because it's the only way they can feel good about themselves, (even when it's just information). I think that's exactly what happened here with you two.
I got my answer, and my life will keep moving on. I may come back in here to help others when I can. Not sure what you two are doing in here, but this thread went well beyond stupid. I think you enjoyed that part, and I think you need to grow up.
Answer has been received. I couldn't care less what you two say from here on out.
/thread.
/thread.
Sure we need to grow up, ok. I gave you the exact answer then you blew up on me saying I was wrong. Time for self reflection bud. Cant take criticism into your method don't ask for it.
My thing is if you knew the answer why did you ask us?
And I'm not gonna explain the clipping process when I can tell you how to avoid it in a much simpler way. The internet has plenty of info on clipping already.
The smd dd1 is a great tool but it damn sure isn't the end all be all. That tool is new like what 5 years since release? How long have we done this before that tool was available? We used formulas based on physics and osilliscopes.
We used to answer these basic questions daily 2007-2012 since then all the car audio forums have fell off.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
707
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
506
HardofWhoring
Phoenix, AZ
Decebal
    Jun 10, 2024
