Cant seem to figure this out
Name'sDEEZ
121
15
Earth
I finished the installation on this jetta but heres the scenario
1 head unit 3 rca outputs 2 for speakers 1 for woofer. When i connect sub to amp it cuts out (only the sub not the amp) unless i remove either L or R rca. Why is that?
I have never heard of a single RCA output off the radio. Usually it is L&R, even if it is a sub channel. Check the sub's impedance; it may be too low and sending amp into protect.
Cuts out how? Just stops playing? I would run a test tone, like 60 hz or something, and compare both L/R RCA AC voltages.
Cutting out by adding an RCA is going to maybe be a short, or like said above, the extra power added could cause another issue to pop up, with the amp probably trying to output more power.
I’d really check to make sure your RCA’s are functioning properly, first.
What Brand and model is the sub? What OHM load did you wire too? What amplifier are you using for that sub?? More information needed here to try to understand the equipment being used and configurations to rule out issues involved.
Cuts out like the sub doesnt play no more. But i never considered the load capabilities of the HU for now i made it work with a stereo to mono rca wire.
Man. We all have had our share of good and bad on here. Ive deff. had my share for sure.. LOL. It all works out in the long run. Excellent to hear...
829
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
Name'sDEEZ
Name'sDEEZ
Earth
ikpthegame
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
