Head unit cutting in and out
GreatTyler
Hello all,
I have been having an issue with my head unit lately and need some help. Whenever a song with decent bass is playing and I turn the volume past 20 every time the bass hits the music cuts out and the head unit goes black for a split second then comes back and keeps playing but the issue keeps happening at every bass hit. I took the head unit off and hooked the speakers up individually and tested them at high volume one at a time and they were all good, it only happens when they are all hooked up. I redid all the connections including the ground and tested the power and it all seemed fine. I am at a loss here and was wondering if anyone had any suggestions, below are my specs
I installed these in my 2011 Honda Accord,
Head Unit = Alpine iLX-W650
Speakers = 4 Kicker 43DSC6504
No sub or amp
I am thinking the head unit itself is shorting when getting a certain amount of power but I'm not sure how to test that. Thanks in advance for any advice
481
756
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
799
997
GreatTyler
GreatTyler
Maryland
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
