Large infinite baffle subs ?
qwiketz
Hi all. I have the Jl marine 12” Infinite baffle sub. I’d ideally like to go up to a 15 or 18. This is for a boat installation. I’d love to get more output with out the additional power draw of a second sub, so I’m thinking bigger.
move used fi ib3’s in my home theater setup so I’m thinking about one of those or any other good sized subs you can recommend that will be
on the jl instructions, it pretty clearly says 3 cubic ft+ for air space. Typically ib installs have large air volumes and I have a decent amount, but nothing like an attic or home closet.I’ve heard from 4x vas up to 25x vas. Any suggestions on what works and what doesn’t in this type of environment?
sub is in awall of my boats mid cabin and the backside of the woofer is in a compartment under the bow seats which is the left side’s pontoon. I’ll have to take a better look, but it’s a decent sized space.
thoughts on this,?
Mate, you can use many subwoofers, but take note of the FS and QTS above 4 would be suited. With any install, it is the installation that makes the sound system sound good in the worst environment like a vehicle or a boat. Applying sound deadening to internal cavities and maybe some wadding may also help dampen any resonance and also provide a more smoother roll off and performance of the installed subwoofer. With IB, usually bigger cone area is king! ;)
Year old post "mate"
Never gets old!😂
Since it’s been a year, time for an update. Got the jl out of the boat and am in the process of making the new baffle. Kind of nervous about hacking up the boat but hopefully the improvement will be noticeable.
Can anyone model these two woofers in a “15” cube sealed box? I think that is roughly about how big the area is for the “enclosure”.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
979
I just built a system not long ago in my 2008 C300. I actually cut out the partition behind the arm rest in the rear seat to act like a port. I...
qwiketz
qwiketz
Orange County
qwiketz
    May 31, 2024
    May 24, 2024
